Assigned gateways are gateways that you put to work inside WisDM by adding them to a location. Below is the primary flow to help you understand more about assigned and unassigned gateways.
WisDM - Organization - Location
When you add a gateway to WisDM, you add them to a location. Without specifying a location, you cannot add a gateway. Once you’ve specified the location and added them, you have an assigned gateway.
Unassigned gateways are gateways that you remove from the location. Removing them means they are not actively working for you but remain within the organization for you to assign to a location later.
Note: If the gateway was assigned to a location and then unassigned, the gateway's LoRa Network settings will be restored to the factory defaults.
Here’s how you can assign a gateway:
From Organizations, go to Locations > click on any location page > tap Add gateway button on the top right corner > fill in the form details on the right, then select gateway under Gateways available >tap Add gateways button at the bottom of the page to complete.
From Organizations, go to Locations > click on any location page > tap Add gateway button on the top right corner > tap Choose button on the left under Unassigned gateways, then select the gateway from the list and tap Apply selected> tap Add gateways button to complete.
From Organizations, go to Gateways > find the gateway you want to assign, then tap on the Kebab (three vertical dots) on the extreme right > from the menu, choose Assign to location > choose the location, then tap Use selected location to complete.
From Organizations, go to Gateways > click on any gateway > scroll to the bottom of the gateway page > tap Assign to location button > choose the location, then tap Use selected location to complete.
Here’s how you can unassign a gateway:
From Organizations, go to Locations > click on any location page > find the gateway you want to unassign, then tap on the Kebab (three vertical dots) on the extreme right > from the menu, choose Unassign gateway > read the information from the pop-up, then tap Unassign button to complete.
From Organizations, go to Locations > click on any location page > click on any gateway > scroll to the bottom of the gateway page >tap Unassign gateway > read the information from the pop-up, then tap Unassign button to complete.
From Organizations, go to Gateways > find the gateway you want to unassign, then tap on the Kebab (three vertical dots) on the extreme right > from the menu, choose Unassign gateway > read the information from the pop-up, then tap Unassign button to complete.
From Organizations, go to Gateways > click on any gateway > scroll to the bottom of the gateway page > tap Unassign gateway > read the information from the pop-up, then tap Unassign button to complete.
